Hello!
I am currently attempting to build a "traditional" bench power supply around a LM723 and four 2N3055 transistors. I have tested parts of the schematics and things seem to work great so far.
However, I have two CX-101-BG panel meters from http://www.circuitspecialists.com/digital-panel-meter-cx101bg.html
that I intended to use for voltage and current display. (These are the -BG ones, that should work with a common ground configuration). After a bit of frustration I managed to get one working for straight up voltage measurement using the second example from the datasheet (don't have a schematic for this, sorry), but i cannot get it to measure the voltage across a resistor properly.
Here is my power supply schematic, R13 is the resistor over which i intended to measure the voltage drop, and display it on the meter.
The "Current limit board" mentioned in the schematic is just another board that switches in various resistors in series to provide a couple of different steps for setting the current limit for the LM723.
So my question is, how do i wire the CX-101-BG up to measure the voltage drop across R13, if it is at all possible? Are any of the COM, INLO, INHI, REL pins internally connected to ground inside the meter?
regards
MaggoT
regards
MaggoT
