cw motor
Discussion in 'General Electronics Chat' started by amruth11, Aug 14, 2011.
  1. amruth11
    May 24, 2011
    49
    Hi guys i am using a cw motor which dosent have leads except for 2 holes in the PCB sticking out and i dont know which one is negetive and which one is positive, plz help me.:)
  2. kubeek
    Sep 20, 2005
    4,691
    806
    what is a cw motor? what voltage, current does it need?
  3. wmodavis
    Oct 23, 2010
    737
    150
    clockwise??
  4. Adjuster
    Dec 26, 2010
    2,147
    300
  5. debe
    Sep 21, 2010
    955
    185
    Heres how to work it out. Put one multimeter lead on to the output shaft of the motor & then check each conection with the other lead, meter set on ohms. The lowest reading will be the negative conection. (Ive asumed by his description its one of these motors)
  6. kubeek
    Sep 20, 2005
    4,691
    806
    Debe, where is the black lead connected?
  7. debe
    Sep 21, 2010
    955
    185
    Black lead is conected to the motor drive shaft, as these motors are surounded by rubber insulation inside & the out side shell is quite often not conected to the motor shell.
  8. debe
    Sep 21, 2010
    955
    185
    A few pics of whats in these motors & they are electronic speed control & adjustable. Normaly purchased in the voltage required & in CW or CCW. They can be reversed by dismantling & unsoldering the PCB from motor & shifting 180Deg & resolder & reassemble.
  9. amruth11
    May 24, 2011
    49
    Thx everyone for the advice the motor is the same type debe has and it is a 9v dc motor.
