cutting sticker
Discussion in 'Off-Topic' started by Lightfire, Feb 22, 2012.
  1. Lightfire
    Oct 5, 2010
    690
    21
    hi guys,
    i want to cut a sticker. i mean for example i print a 4x4 circle in a A4 size sticker paper. i want to cut the circle. would that be possible? (i mean if there is any printer which cut the circle)
    or that need a huge expensive printer?:)
    thnx
  2. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    They make laser cutters that can cut paper, but they are quite expensive. Personally, I would use an Exacto knife, though you should have an adult help you. They have open blades and are extremely sharp, so I wouldn't recommend doing it by yourself. They are cheap and you can find them just about anywhere (at least in the U.S.). They look like this:
    They are very handy for cutting out shapes from paper :D
    Regards
  3. Lightfire
    Oct 5, 2010
    690
    21
    oh ok. can it cut letters so precies?
  4. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Yes. It is very sharp and the tip is very small. It will be easy to cut out small letters very easily. But please have your mom or dad help you, just to be on the safe side ;)
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Something I do when I need a custom label is use carpet tape, which is double sided. The stuff simply will not let go. Put it on the back of a custom print out and you are good to go.
    The downside is carpet tape is tough, it does not cut easily.
  6. bretm
    Member
    Feb 6, 2012
    152
    24
  7. maxpower097
    Feb 20, 2009
    795
    388
    Dude sticker printing is so so so cheap right now its cheaper just to have it done and cut, then try to do it yourself. The cost in materials will be about the cost of having them professionally done. I've made lots of em. There stupid cheap.
  8. maxpower097
    Feb 20, 2009
    795
    388
    You know to get graphics and fonts for this thing they come in nintendo like catriages. And cost liek $30 each and contain like 50 images. I was thinking of making some of the cartraiges to sell myself if it was possible.
  9. maxpower097
    Feb 20, 2009
    795
    388
  10. bretm
    Member
    Feb 6, 2012
    152
    24
    I don't know about making cartidges yourself, but the device is hackable so you can cut any shapes you want.
  11. Sparky49
    Jul 16, 2011
    835
    417
    If you're going down the knife route, make sure it is as sharp as possible.
    A blunt knife is a dangerous knife...
  12. Wendy
    Mar 24, 2008
    20,772
    2,540
    And use a thick cutting board! Mom is not going to be happy if a counter or table top suffers because of this.
  13. Sparky49
    Jul 16, 2011
    835
    417
    *cough cough*
