True, but they want a high price for what you can get from a wholesaler's scrap bin for next to nothing and as I mentioned, you may as well stock up at the prices they're willing to sell if for.Just about any place that sells window glass or repairs windows has the Lexan now days.
The sandwiching between wood idea also works for sawing too.
I have never used a wood sandwich. Sounds like a dreadful thing to try on a table saw.Sawing or drilling through any plastic can be a pain but as mentioned many times above sandwiching it between some wood pieces will help a bit, however then the heat builds up more readily.
That's because you are thinking of a water bath. Try a water sponge. Cheap, cellulosic sponge, just wet, not dripping. Position it so the blade cuts the sponge and plastic at the same time. Also works great for cutting ferrite or glass with an abrasive cut-off wheel. For drilling, all I use are a few drops of water.Even though it's rarely practical a water bath can be of some help and only experimentation will find you the right blade and speed at which you can cut.
It is in my profile. I live in Pittsburgh, PA.Naw, you just aren't looking close enough in your YP. Start by looking for plastics then wholesale.
If you'd finish filling out your profile as far as location I'm sure I could find you several not far away. It's also nice to have the choice of the different colors such as slightly smoked or light bronze. If a red LED readout is the target then it looks better behind red, etc. and they have all of that.
Just let me know what town you're located in and I grab you a local supplier's # or two.
