no problemYa, high pass sorry about that.
Do you know how to calculate the impedance Xc of the 10uF cap.?Yes, i don't know how the resistor connected in parallel with the capacitor affects the value.
Ok,yes 1/(2pifc)
At Freq=0 the Xc is infinite, so the attenuation ratio from input to output is 1:0.5what does the resistor connector in parallel to the capacitor do then?
hi,Ok solved it using transfer function thx.
Hola rondo,Ok solved it using transfer function thx.
Hi.Hola Eric,
I am surprised I completely forgot how to suscribe to a thread (this one in particular now) other than posting in it. (?)
Could you please tell? Gracias.
3dB point is at 1/sqrt(2) ~ 0.707Ok,
As this is homework I cannot give you the answer, but consider.
What the attenuation in the Output when the Freq=0 , also whats the attenuation when the Freq > 1000Hz.??
This should give you a clue that some value of Xc will give an attenuation of 0.5.
Did you get the same answer 4.226 Hz as in your first message?Ok solved it using transfer function thx.
When viewing a thread, go to the top of the first post on a page and select "Thread Tools". One option is to subscribe to the thread.Hola Eric,
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Jake Hertz
