Currents in different parts of resistor
Discussion in 'Homework Help' started by logearav, Nov 18, 2015.
  1. logearav
    Aug 19, 2011
    248
    Please refer my attachments, revered members.
    In Step 2 the 4 ohm resistor is removed, its been mentioned that no current will go through any resistor. Why? Still current can flow through the 4 ohm resistor that is connected in the right extreme end, can't it?
    Again, it has been mentioned that if 4 ohm resistor is added between d and e, no current will be drawn into it. Can i know why? Scan_20151118 (2).jpg
  2. DickCappels
    Aug 21, 2008
    2,772
    669
    Current through a resistor equals the voltage across the resistor divided by the resistor's resistance. Since both e and d are at the same voltage, no current would flow through a resistor connected across those points in the circuit..
  3. Jony130
    Feb 17, 2009
    3,991
    1,116
    Please do the circuit analysis and solve the circuit and then you will know why.
  4. logearav
    Aug 19, 2011
    248
    Thanks for the reply sir.
    I = V/R. The extreme left resistor of resistance 4 ohm is connected to voltage of 2V. So current is 2/4 that gives 0.5 A of current. How then we conclude no current is flowing through any of the resistor?
  5. Jony130
    Feb 17, 2009
    3,991
    1,116
    Please notice that Va = 2V and Vc = 2V. So the Left and the right resistor will see the difference in this voltage.
    Vd = Va - Vc = 2V - 2V = 0V; And I = Vd/(4Ω + 4Ω) = 0V/8Ω = 0A
  6. logearav
    Aug 19, 2011
    248
    Thanks sir.
    But the point d is connected to the positive terminal of the battery and point b is to negative terminal. If we assume the potential at b to be zero then Vd is 2-0 so 2V. How it is zero as mentioned by you, sir?
  7. Jony130
    Feb 17, 2009
    3,991
    1,116
    Sorry for confusion. I did not notice that you already have Vd on the diagram.
    So let as start again
    The voltage difference between point a and b is equal to :
    Vac = Va - Vc = 2V - 2V = 0V
    And this means that no current can flow between point a and c. So, no current in left and right resistor.
    I = Vac/(4Ω + 4Ω) = 0V/8Ω = 0A
    If this is the case the voltage at point e is also equal to 2V
    Ve = Va - I*4Ω = 2V - 0A*2Ω = 2V
    And the middle resistor current is Im = (Ve - Vd)/Rm = (2V - 2V)/4Ω = 0A
  8. logearav
    Aug 19, 2011
    248
    Thanks again sir.
    Voltage difference between a and b should be Vab, Am i right or as mentioned by you i.e Vac?
  9. Jony130
    Feb 17, 2009
    3,991
    1,116
    I meant to say: the voltage difference between point a and c is equal to : Vac
    logearav likes this.
  10. WBahn
    Mar 31, 2012
    18,087
    4,917
    You are making one of the classic mistakes and throwing the nearest V and the neared R at Ohm's Law and getting an irrelevant value that happens to have the units of current because you aren't paying attention to what Ohm's Law means. You need the voltage ACROSS the resistor -- not the value of some battery that happens to be connected to one side of it.
  11. logearav
    Aug 19, 2011
    248
    Thanks a lot for clarifying. Voltage across -- i got it sir.
