Current / Voltage source
Discussion in 'General Electronics Chat' started by MartinV, Jun 2, 2011.
  1. MartinV
    Jun 2, 2011
    22
    I am new to this part of physics (electrotechnics) and I am finding it a bit confusing to get the point of these components of a circuit. So I would be very grateful if someone could explain these (even shortly) their functions.
  2. #12
    Nov 30, 2010
    16,705
    7,355
    A constant voltage source, also known as a voltage regulator, attempts to provide a steady voltage as the load changes. It is said to have low impedance because changing the current that flows does not change the voltage very much.
    A constant current source attempts to always have the same current flowing through it, no matter how much voltage is applied, as long as there is enough voltage to operate the current source, but not enough to destroy it. A constant current source can have very high impedance and is sometimes used as a load, in place of a resistor, because it allows enough current to operate the idle current of the amplifier, but refuses to change current when AC is applied to it.
    Good start?
  3. MartinV
    Jun 2, 2011
    22
    How does the voltage source affect the current flow? I read something about about the voltage source making potential differences that make the electrons (current) move opposite of the electrostatic field, and I was quite confused by that.
  4. Adjuster
    Dec 26, 2010
    2,147
    300
    There are real-world systems, such as just described, which approximate to current and voltage sources. On the other hand, in circuit analysis these items are often considered as idealised abstractions.
    These may be found as elements of problems requiring solution, or else they may used as part of models describing the operation of other circuits. If you continue to study this subject you are likely to encounter Thevenin (voltage) and Norton (current) equivalent circuits for networks, as well as a variety of models for semiconductor devices, which generally use so-called controlled sources, whose output depends on conditions elsewhere in the circuit.
  5. MartinV
    Jun 2, 2011
    22
    The shameful part is that I've met with Thevenin's method but I've been using it schematic. I wanted to understand these components deeply. I wanted to know how will the multiple voltage sources will contribute to the changing of the current intensity, and how will they affect each other.
  6. #12
    Nov 30, 2010
    16,705
    7,355
    Speaking of "components of a circuit" (post #1) what component has this "electrostatic field" (post #3) of which you speak? How many "multiple voltage sources" are we talking about? How are they connected that they would change the current intensity (post #5)?
    I am completely lost right now.
  7. Adjuster
    Dec 26, 2010
    2,147
    300
    I don't think that there is all that much to be confused about. The choice of positive and negative terminology was originally made arbitrarily, before the electron was identified as the carrier of electric current. Later on, the electron was discovered and turned out to have a negative charge according to the already entrenched convention - it was too late to change it.
    We simply have to accept that the electron has a negative charge. Opposite charges attract, and like charges repel. Positive, then, is what attracts electrons, namely a relative lack of them.
  8. MartinV
    Jun 2, 2011
    22
    The electric field is a part of definition, so forget that part.
    Here's an example. If we know the amount of Volts of E10 (voltage source) and the ohms of the resistor R10 we can easily get the amount of I10. Is that right?
    (Look at the picture below)
    http://imageshack.us/photo/my-images/191/circuitx.jpg/
  9. MartinV
    Jun 2, 2011
    22
    My question is, if we say E=I*R, does that mean that the current through the voltage source (E) is the same as the current entering that "branch" from the near ones?
  10. KJ6EAD
    Apr 30, 2011
    1,426
    364
    No. The circuit contains 4 other voltage sources and 9 other resistance elements that must be accounted for.
  11. KJ6EAD
    Apr 30, 2011
    1,426
    364
    Yes. It's the only path.
  12. MartinV
    Jun 2, 2011
    22
    What do you mean by "the only path"?
  13. Adjuster
    Dec 26, 2010
    2,147
    300
    We need to be very clear here. The OP must understand that, for his circuit, one cannot say that E10 = I10/R10
  14. MartinV
    Jun 2, 2011
    22
    What is OP, and do you mean E10=I10*R10?
  15. KJ6EAD
    Apr 30, 2011
    1,426
    364
  16. MartinV
    Jun 2, 2011
    22
    So we look at that path (the one including R10 and E10) as it was isolated?
    The node method should do the job here, right?
  17. KJ6EAD
    Apr 30, 2011
    1,426
    364
    No because it isn't. It's part of a network. You must use one of the network analysis techniques. Read the Wikipedia article section on choice of method.
  18. MartinV
    Jun 2, 2011
    22
    Yes I know that now, since you edited your previous post :)
  19. MartinV
    Jun 2, 2011
    22
    Thanks guys, after tormenting you a bit we got to the wanted question/answer.
  20. KJ6EAD
    Apr 30, 2011
    1,426
    364
    The forum doesn't make a very good chat system. It also doesn't show edited posts as new when you log in again. I guess I should flag my edits better.
    MartinV likes this.
