Current Transmitter (XTR115)
Discussion in 'The Projects Forum' started by Angoera SE, Jan 26, 2010.
  1. Angoera SE
    Jan 26, 2010
    I have a problem with a current transmitter XTR115, because I put two XTR115 in the same board. The circuit is attached....
    Thanks........
  2. atferrari
    Jan 6, 2004
    2,674
    785
    Could you describe yours? Advination is not my strongest point...
  3. Angoera SE
    Jan 26, 2010
    Sorry for my poor explication.
    When I use just one 4-20ma output, using one external +15 source and one 250 Ohms resistor the circuit works fine, the problem is when I use the two outputs, the current that I am reading is not right in both chanel. It is attched the conection with the external source...
