Current transformer
Discussion in 'The Projects Forum' started by saurabhkarnik, Jul 20, 2008.
  1. saurabhkarnik
    Jun 22, 2008
    22
    can anyone gimme circuit using current x'former so that i can see the current waveform using CRO... it should shift wrt to voltage waveform when the phase angle of the supply is varied
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. saurabhkarnik
    Jun 22, 2008
    22
    well this is what i want...
    current x'sformer should be connected to source in such a way that by varying the phase angle of source the o/p waveform phase should change accordingly.....
    i.e i want to see the current eq waveform on cro...
    or any circuit which will show me the current eq waveform on cro i.e when phase shift is given to the source i should see the waveform shift on the cro wrt to the voltage waveform of the source...
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Do you mean an oscilloscope with CRO?
    What is WRT?
    Greetings,
    Bertus
  5. saurabhkarnik
    Jun 22, 2008
    22
    WRT means with respect to..
    and yes... by cro i meant oscilloscope
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Here are 3 PDF's with information on current transformers.
    Greetings,
    Bertus
  7. saurabhkarnik
    Jun 22, 2008
    22
    sorry but that didn't help...
    the whole thing was about detecting phase angle between the voltage and current...
    tried using current former but didn't work...
    i'm desperatly seeking circuit that can give me phase angle between supply voltage and current.. the following type of circuits will do
    1) circuit which wil give me current and voltage waveform at the output ............ the should change in phase when power supply phase angle is varied
    2)circuit that will generate voltage signal proportional to the phase angle between current and voltage
  8. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  9. saurabhkarnik
    Jun 22, 2008
    22
    well plz suggest a circuit where, wen it's output connected to cro will show me current waveform... that was whole purpose of the current transformer....
    changing the phase angle of the supply should change the phase of the voltage waveform with respect to the current one
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    Do you have an Oscope?
    You ought to read this section of the AAC eBook, with special emphasis on this chapter.
  11. saurabhkarnik
    Jun 22, 2008
    22
    well let me get it like this
    u can't observe current waveform on CRO...
    please gimme circuit to separate the voltage and current waveforms so that when i change the phase of power supply there's phase change in the current and voltage waveforms of that suppl observed on CRO..
  12. jpanhalt
    Jan 18, 2008
    5,699
    909
    I have had good luck with this current probe. John
  13. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  14. saurabhkarnik
    Jun 22, 2008
    22
    thanks a lot u ppl....
    u ppl really helped a lot
