Hello dear community,
I've measured the current impulse of an impulse magnetization machine. In order to measure the Impulse I installed a rogowski coil and a normal current transformer with a ferromagnetic core at the supply line of the magnetization coil. They measure the same impulse curve - see attachment - but at the zero crossing you can see that with the current transformer the curve is remaining at the zero level. In contrast to it, the rogowski coil shows a negative offset. Ther was no offset at the beginning of the measurement. My question ist: Why does the rogowski coil show a negative offset at the end of the impulse? Has it got anything to do wiht the evaluation unit (integrator) of the rocowski coil?
Thanks for your help!!!
Andi
Andi
