Current Transducer + Output Indicator
Discussion in 'The Projects Forum' started by koszowo, Nov 2, 2010.
  1. koszowo
    Nov 2, 2010
    Hi All
    I have a LEM current transducer with 0-10V output
    http://www.lem.com/docs/products/at_b10_e.pdf
    I want to have a LED or lamp or anything that will indicate that there is any voltage on the output of the current transducer.
    eg. 0 V - indicator off
    1V up to 10V - indicator on
    Is there any LED or lamp that will work on 0-10 V ?
    Thank for help
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    The device appears to be a voltage only (limited current) output type.
    It may not be capable of delivering sufficient current to directly drive an LED.
    You would (for instance) be able to buffer the transducer output with a high impedance op-amp circuit which could subsequently drive an LED. But that would require an auxiliary DC supply to power the buffer circuit.
  3. koszowo
    Nov 2, 2010
    Do you know if there is any device that could do it?
    Could you give more details how to do it?
    Thank you
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    Perhaps it would help if you gave a more detailed listing of your requirements including
    1. Required primary current range.
    2. Do you only want to detect the presence of primary current or do you also want to measure the actual primary current value?
    3. Whether or not you are limited to using a self-powered transducer.
    4. Would you consider using a secondary side powered transducer?
    5. Whether you have sufficient skill to build any additional interface electronics.
    6. Are you on a very limited budget?
  5. koszowo
    Nov 2, 2010
    Thanks for answer. Please find my answers below.
    Primary current range 0-5 A
    I want only to detect the presence of primary current.
    Self-powered transducers are preferable.
    It could be an option.
    Skills are probably not sifficient but I want to try.
    not very limited but limited.
    I hope this helps
  6. wayneh
    Sep 9, 2010
    12,376
    3,226
    I wonder if you couldn't just light an LED directly with a device mounted right NEXT to the transducer? At that current range, I think a few loops of wire - an in situ transformer - might give enough juice to power an LED, which could probably be protected against over-current with a zener or other current limiting trick. Downside is the need to loop around the main conductor.
  7. koszowo
    Nov 2, 2010
