Current to voltage conversion
Discussion in 'The Projects Forum' started by schnnegi, Nov 8, 2008.
  1. schnnegi
    Sep 24, 2008
    9
    Hi friends, Is there any provision for IC which has multiple current to voltage convertors about 6 in the conversion range of 4-20mA into 0-3.3V(or 0-3V).
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    An op amp and a resistor will do this quite nicely, and you can get quad op amps.
    Vout = R X Current
    If you need an inline current measurement it gets slightly more complicated, think shunt resistor with differential amp (another op amp circuit).
