Current sources for load referred to ground
Discussion in 'General Electronics Chat' started by atferrari, Nov 26, 2014.
  1. atferrari
    Thread Starter AAC Fanatic!
    Jan 6, 2004
    2,668
    784
    After reading about constant current sources, I defined the four cases shown in the pdf. Current should go up to 250 mA.
    Implementing B and C with the attached circuit (and its counterpart) is straightforward, but I am not sure how to proceed for A and D. I cannot have Rsense referred to ground anymore.
    How could I go away with no fancy ICs?
    Gracias for any help.
  2. crutschow
    Mar 14, 2008
    13,503
    3,376
    Here's a high-side current source with differential inputs, using a standard op amp, that may be of interest to you.
    atferrari likes this.
  3. atferrari
    Jan 6, 2004
    2,668
    784
    Wow. Quick and to the point. Have to find time to see how it works.
    High-side, have to retain that name.
    Gracias!!
  4. studiot
    Nov 9, 2007
    5,005
    515
    Two transistor two terminal topologies.
