Current Source
Discussion in 'General Electronics Chat' started by BoJ, May 6, 2008.
  1. BoJ
    May 6, 2008
    Hello!
    I want to build a circuit where I have a load of 10 - 15K and a DC source of 12-20V max.
    I want to have a minimum current of 8-10 mA through the load.
    Is this at all possible or not?? (I know that supposedly I would need a min voltage of about 80V, but I was wondering if it were possible through any other way..)
    Thanks in advance.
  2. Caveman
    Apr 15, 2008
    471
    Nope, you want 8mA through 10k, you gotta have 80V. That's how it works. See ohms law.
  3. KMoffett
    Dec 19, 2007
    2,584
    234
    Switch-mode boost converter power supply . 12-20vdc at ~0.1A input...>80vdc output. No specific circuit in mind, but that would give you what you asked.
    Ken
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Perhaps you can elaborate on your application. Then we may be able help you refine your requirements a bit.
    hgmjr
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You could build a flyback converter.
    Check out this page:
    http://www.dos4ever.com/flyback/flyback.html
    To get 10mA through a 15k Ohm load, you'll need 150v.
    There's a Nixie tube flyback supply on the link that will output 180v from a 12v supply.
    If you're new to electricity/electronics, I recommend that you stick with circuits that are under 50v until you get about 1,000 hours worth of studying and practical experiments under your belt.
