Current source/sink
Discussion in 'The Projects Forum' started by johnkaz77, Sep 20, 2010.
  1. johnkaz77
    Sep 20, 2010
    33
    Hi everyone!My design has a power supply of 1.8V and i want a current source/sink to provide me from -10uA to 10uA but i don't have much experience in electronics and i don't have a clue :confused:...Can anyone help me??
    Thank you for your time.
  2. windoze killa
    Feb 23, 2006
    605
    24
    Can you explain what this power supply is used for. 1.8V sounds like it is for some microcontroller or similar. Can you provide a bit more info.
  3. johnkaz77
    Sep 20, 2010
    33
    My design has an ASIC with a pad in which i must provide the current i mentioned.I have a regulator,which gives me 1.8V(power supply to the ASIC) and through that pad i told you,current will be drawn or injected,depending on some other parameters (the ASIC internally has a circuit to absorve or provide current to some amplifiers but i don't know further details about it),so i have to provide current from -10uA to 10uA.Does this make any sense now or did i make it worse?
