I wanted to use a current shunt amplifier to measure the current through a circuit. I was thinking of getting the INA212 from TI because it has a Gain of 1000. The reason for this gain is because I want to be able to go down to nano-amps. I wanted to know what's the minimum voltage that the device can measure between the two pins because I want to get a Rs as small as possible. I want to be able to set a constant current or voltage so there is a feedback. Should I put the current sense on high side or low side? Suggestions?
Here's the link for the component.
http://www.ti.com/product/ina212
Thank you!
Thank you!
