Current Sensor
Discussion in 'The Projects Forum' started by Cerkit, Mar 10, 2009.
  1. Cerkit
    Thread Starter Active Member
    Jan 4, 2009
    275
    Hi. I'm trying to setup a current sensor. How can I set it up in order to measure current in the following circuit
    Code ( (Unknown Language)):
    1. Vdd-------Load-------Gnd
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. Cerkit
    Jan 4, 2009
    275
    Yeah. Not helpful unfortunately because if I could use an ammeter for the job I would. I am only allowed to measure voltage in my project using an ADC.
  4. mik3
    Feb 4, 2008
    4,846
    63
    What kind of load is it?
  5. Cerkit
    Jan 4, 2009
    275
    Resistor load
  6. mik3
    Feb 4, 2008
    4,846
    63
    If it is a resistor load just measure the voltage across it and divide by the resistance to find the current.
  7. Cerkit
    Jan 4, 2009
    275
    The resistor value is unkown hence I need the voltage and current readings.
  8. mik3
    Feb 4, 2008
    4,846
    63
    Put a 1 ohm resistor in series with the load and measure the voltage across it. The voltage across the 1 ohm resistor will equal the current through it.
