current sensor using oh49e sensor
Discussion in 'General Electronics Chat' started by mah, Dec 20, 2015.
  1. mah
    Thread Starter Active Member
    Mar 15, 2010
    276
    could i use this sensor oh49e to measure current ranging from 0-5 A to monitor it on lcd using microcontroller?
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Data sheet
    You might need to wind the current-carrying conductor into a solenoid on a core, and then insert the hall sensor into a gap in the core to get enough sensitivity...
  3. Lestraveled
    May 19, 2014
    1,957
    1,217
  4. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,508
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Or you could have a look at the sensor attached in the PDF.
    Bertus
  6. PeterCoxSmith
    Member
    Feb 23, 2015
    148
    38
  7. Lestraveled
    May 19, 2014
    1,957
    1,217
    Nope
    An OH49e is a raw Hall effect device. It has no input current terminals.
    The sensor I linked to is complete.
    PeterCoxSmith likes this.
