current sensing
Discussion in 'General Electronics Chat' started by Jaguarjoe, Feb 7, 2011.
  1. Jaguarjoe
    Thread Starter Active Member
    Apr 7, 2010
    770
    90
    Is there any one current sensing IC better than all the rest? My plan is to use a 0.01 ohm sense resistor and a CS IC with a gain of 100. That way 1 amp max will be 1 volt out of the chip.
  2. timrobbins
    Aug 29, 2009
    318
    16
    A cheap IA may be the best way to go. Eg. as used for microphone amps such as INA217, INA163. If you scope out the performance you need a bit more, or the circuit limitations (eg. supply rail, bipolar output, noise level, frequency response).
    Ciao, Tim
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    I have a project that will need a instrumentation amplifier across a low value resistor. The advantage is no reference points such as ground or Vcc need be considered.
    I know this in theory, but have yet to work out the fine points.
  4. jaclement
    Apr 15, 2009
    34
    Jameco sells a hall effect device with output proportional to the magnetic field . If it sensitive enough, this could be used to sense current. this would isolate the current sense from the measuring circuit.
