Indeed 1mV/Amp.hi patpin,
The gain of this demo circuit is set to give a -/+1Vout range for a Vhall signal of -10mV thru +10mV.
E
E
I have followed yr diagram with the 2 100K R's. It influences the output of the Clamp-on current meter (=input of the 623). It becomes -5,2mV without 1A current running throught ferrite and -5.7mV with 1 Amp . But the output of the AD623 remains at 1.61V. I tried to augment the gain of IC1a; The difference between measuring 1 Amp and not, became larger (1.2mV) but still no change in output of AD623hi,
A common way is to use say a TL431 reference driving a OPA, the output of the OPA would be connected to the Vref pin.
If you configure the TL431 ref source to be adjustable, you can set the Vref to suit your application.
E
Hi Eric, Before trying to realise the diagram you designed (many thanks for it) , a few questions.hi patpin,
Using your Hall device I would suggest this option as being an improvement over your original circuit.
Its uses an OPA to give a Virtual Gnd [vg ], the 2.5vg is based on the Hall device datasheet typical value of 2.5V quiescent output, which has a possible Q range of 2.25v thru 2.75v.
It would require that you set the Vg voltage to suit, using the 1k pot.
As I do not know the coupling coefficient of your Clamp/Hall I have assumed -/+10mV swing for -/+10Amps.
Your DVM [ connected between Vout and Vg] would show a range of -1v thru +1v for -/+10Amps, for the sim circuit.
E
#36 (91K)Which post number has that diagram with 100K?
E
yes 91k...#36 (91K)
hi,Can I assume that "U5" in
Thanks again for the simhi,
U5 is the circuit Ident for the 1K pot, the 'wiper= 0.58' value, indicates that the pot has been rotated 58% of its travel.
It sets the voltage of the virtual ground, which is typically 5v/2.
I assume that as you show a 9V voltage supply, that the project is powered from a 9v battery.??
If so, the project is 'floating', that means that your Scope 0V common Input can be connected to Vg [ vehicle chassis neg] and the Scope signal Input connected to Vout of the IA.
Are you requiring to view a sharp 1000Hz square wave current signal on the Scope or just a 'rough' 1000Hz signal.??
E
EDIT:
This image shows how the '9v battery powered floating' circuit would connected to the vehicle battery/Scope
Hi Eric , I realised yr diagram in post #40. It is functioning: For a Hall change of -1mV the output referenced to Vg changes from 0 to -1.74 VOLT!. which is a little bit to much gain. What is the best way to reduce it to about 100?hi patpin,
E
The usual way would be to make the 'gain' resistor, presently a 1k01, a variable pot. [pins# 1 and 8 of the AD623]What is the best way to reduce it to about 100?
Indeed I also checked this table and expected gain 100 instead of 1700 as measured now, but this is probably due to the BC547. Anyway I 'll put a potmeter and the probl will be solved. Thanks.The usual way would be to make the 'gain' resistor, presently a 1k01, a variable pot. [pins# 1 and 8 of the AD623]
ie: a fixed 1K resistor in series with an adjustable 5K pot, this would give a gain control of 15 thru to 100 times.
E
Indeed I measured between Vo and Vghi,
The DVM should be connected between Vout and Vg, not Vout and 0V
I would say that as the BSS is powered from the USB, the 0V side of the Input signal of the BSS is connected also to 0V, you could check this by using a Ohm meter [ with the BSS disconnected from the USB port.]
It should be possible to see the injector waveform 'spike' on BSS Scope.
The EHT cable 'Sync' pick up could be problem, you could consider a Opto-coupler with output clamping diodes before the BSS sync input.
Do you have details of the capacitive EHT pick up.?
E
Do you mean one or more varistors? Where do you put the opto-coupler protection considering the given diagram of the High Voltage pickup probe; which optocoupler would you use and what kind of varistors: for what voltage and how many joules? Sorry ... there are a lot of questions again...hi,
i'am afraid I don't understand what you exactly mean by that.hi,
E
In my case its also a hall sensor. Could be interesting to see the output of it with the scope in case there is no firing at all.hi,
As well as the injector current waveform do you want to view the distributor contact waveforms.?
by Aaron Carman
by Aaron Carman
by Duane Benson
by Jake Hertz
