solved
MaxHeadRoom Joined Jul 18, 2013 28,696 Nov 19, 2016 #2 AFAICR it is a very low resistor in the gnd connection of the FETs into the sense pin. fraction of an ohm is required Max.
Alec_t Joined Sep 17, 2013 14,327 Nov 20, 2016 #3 The value of the current-sense resistor is chosen such that it drops 100mV when the motor current is the limit value you want. For example, to limit the current to 1A the resistor value would be 100mV/1A = 100mΩ.
