I have an old battery operated mattress inhalator pump. Here is a link to the new updated version:
http://www.campingcomfortably.com/coleman-rechargeable-quickpump.html
The pump has stopped working. The battery seems to be charged but does not run the motor and battery voltage goes to zero volts when I hook the motor to the battery.
So I hooked the motor to my homemade PSU. The motor ran. I could see the voltage start to drop (which is I am assuming the regulator going into thermal shutdown) and the 1.5A fuse blew.
So I am guessing the motor is requiring somewhere over 1.5A.
Now since the battery is old and worse the charger lacked any kind of charge controller, the battery is probably bad but I am curious why this motor is requiring so much current to run. Is this normal or do I just have a bad motor?
