You can find a 1.2-30v 5A CV/CC supply in the datasheet for the LM117 in National.com site, at page 18. Take a look:
The LED should be red color. V+ in the LM301A should go to the output voltage, i think.
Since you already have the LM338, which is like a higher current LM317, i bet you can use it just fine.
All polarized capacitors are solid tantalum.
The MJ4502 has a thermal resistance junction-to-case of 0.88°C/W, and a maximum junction temperature of 200°C, but nobody goes higher than 150°C, and even that is very risky.
The heatsink you need must have a thermal resistance of:
TJmax is the maximum allowable junction temperature.
TAmax is the maximum allowable ambient temperature (for example: 35°C, if you want this to keep working at that ambient temperature).
PDmax is the maximum power dissipation, which in your case is 35v * 5A.
RthJC is the thermal resistance of the transistor's junction to it's own case.
RthCS is the thermal resistance between the transistor case and the heatsink, that varies depending on the thermal grease, mica, silpad, or whatever you're using between the transistor and heatsink.
Can you calculate the heatsink you need for one and two transistors, or whatever number of transistors is necessary?
By the way, paralleling transistors requires to add an emitter resistor for every transistor, in the order of 0.1 ohms. The power rating of the resistor would depend on the amount of current it's going tru them.
\(\frac{TJmax - TAmax}{PDmax} - \frac{RthJC + RthCS}{numTransistors}\)
