describe the Switching method pleaseDo you really need 0 to 30v and up to 5A? Because the problem with linear regulators in wide-range variable voltage supplies (and to make things worse, high-current) is the power dissipation
In CC current not vary with load but this is how possibleDid u understand constant current or not?
all the okMethod:
Use a transformer to drop the mains voltage to just above the MAX voltage of the PSU you want to build.
Rectify the AC to DC.
Use filters to clean the supply as much as possible.
first i use with transformer power supply with regulator useUse a variety of linear regulators with heatsinks to keep the power dissipation at reasonable levels.
what is e-bookIf you are not understanding, you need to read the eBook and get a grasp on the terminalogy first. Then things will start to make sense.
for home use an electronics hobbyYou DO NOT need suck a suppy to start an electronics hobby or education.
okIf you want to use lm338, you need to use 5 or 6 of them together in a circuit to get the 5a out of the circuit.
What you are not understanding, is the 1A is for 1 IC. If you use multiple, you add together the current it can handle.
If you look at schematics of higher current PSU, they use more than on LM338.
This requirement IS a problem for me.in lm338 use 5 IC use for as current limiter and 5 ic use for voltage regultor that a very large circuit and expensive circuit
please any other circuit diagram send whose cover my requirement
please donot angry i serious for making power supply. in market a very little power supply can handle 0-30V and 5A these supply make usnig transister as regulator
i know that retched you are a very knowledgeable man na s this requirement is not problem for you
please solve my problem thanks
i buy heat sinkIt isnt just attaching a few wires. You will need to buy chemicals and copper clad to make you own circuit boards, you will need to buy expensive heat sinks, and a fan, you will need to but a transformer capable of handling the current and voltages. You will need a complicated circuit for selecting between the 0v and 30v, and a display that will show you what voltage it is set to. I dont think you have any IDEA what your in for.
no you are wrong i dont spit and rockIf I gave you the help, are you going to say thanks for 15 posts, then say "Now how do I do this with a rock and some spit?"
i buy the lm338 because in datasheet Says "guranteed 5A regulation"This is not up for negotiation. When we say 'NO, IT WONT WORK" you cant keep telling us, "But the datasheet says 5a".
i 3 year diploma holder in electronicsIf you have not read books or taken classes in electronics, you DO NOT know how to read the information. We try to help you, and you act like you are taking the advice, but then you come back and say, ok now how about LM338?
i am student and you are my teacher please dontmind and i respect youSo, when you ask for information, and we give you information that you dont want to hear, you just keep asking someone else.
That is what is making us loose patience with your project.
You are a STUDENT. You are using the FORUM as your TEACHER.
You must treat your teachers with respect. And the way your acting, is disrespectful.
We say no, and you ask someone else in the same thread. and they say no. and you continue.
FIRST, are you going to LISTEN?
[/QUOTE
Ok
i want design a power supply that requirement you are knowSECOND, what components (besides LM338) do you have access to?
problem is that the supply in market that is small supply whose cover complete requirement
i design that is small supply whose complete cover requirement
i buy rectifire and filter cct and trnasformer
i can help about regulator circuit
electronic experiment is my hobby and for hobby dose not seen budgetTHIRD, what is your budget? How much money do you have to spend on this power supply?
but i think a small power supply whose cover requirement that in market small power supplies
You do not know how to read in English:i buy the lm338 because in datasheet Says "guranteed 5A regulation"
i read data sheet and i understand that lm338 5A regulator
in data sheet if vin-vout = 30V the max output current can handle 1A
mean
vin = 38 V thus 0-8V can handle 1A max
No.other
vin-vout less or equal 10V than 5-7A max
mean
38-28 = 10
28 or above voltage can handle 5 to 7A
i am right or not
Nobody knows. Measure one to see if the current reduction when the Vin - Vout is high is linear. It changes a little when the temperature changes.in between these two stages 8 to 28V how many current handle = ?
hello audioguru please explain this topic with exmplesYou do not know how to read in English:
When the rating is Vin - Vout= 10V then with an input of 38VDC the output is 1A max when the output voltage is 0V to 30V. They do not say the typical output current with a high Vin - Vout so it might be only 100mA.
by Aaron Carman
by Duane Benson
by Duane Benson
