thanks Norfindel
i dont understand spanish for speak and writeUmer_Farooq, do you speak spanish? I'm from Argentina, i can help you with the languaje a little.
i understand this explaination good explanationEnglish: CV/CC power supplies are like any fixed voltage power supply, but if output current exceeds the set value, the voltage output lowers to keep output current at that maximum value. Ie, they're constant voltage supplies, but won't deliver more than the set current. To avoid current raising more than it should, the output voltage must get lower. Ohm's law is keeped at all times. That means that if you configure the supply at 10v 1A, and put a 20ohm resistor as load, the output is going to be 10v 0.5A, but if you put a 5ohm resistor, with a normal fixed voltage supply, the output will be 10v 2A, but with the CV/CC supply limited at 1A, the output is going to be 1A 5v (1A*5ohm=5v).
