Current Protection Circuit
SLK001
Joined Nov 29, 2011
1,549
Table 1 of the datasheet shows a range of desired currents and the corresponding R(ILIM) values. A simple interpolation between two values will give you your resistor value. C16 is stated to be a 10μF, low ESR cap. You should also add a cap to VOUT per the datasheet.
