Current Path in Swimming Pool ?
Discussion in 'General Electronics Chat' started by morrobay, Nov 7, 2013.
  1. morrobay
    Nov 7, 2013
    11
    A person is in a swimming pool with metal drain and ladder and the underwater
    pool lamp malfunctions with live wire in pool water contact.
    Is it correct to say they will only be shocked if they are between E source
    and drain or ladder ?
    Also what is the shape of the current path ?
  2. #12
    Nov 30, 2010
    16,705
    7,358
    The current path is shaped as if the water is made of trillions of 1 ohm resistors connected in a matrix. They all connect to the voltage source and the grounds, some grounds being better than others. I think people are better conductors than pool water and so, can distort the flow, in bad way. The current would tend to take a shortcut through the person that is saltier than the water, but to a limited degree. Point being, a person that is not directly in the current path can possibly distort the current path with bad results.
    Remember, it's only my opinion, and sometimes I am wrong.
  3. wayneh
    Sep 9, 2010
    12,403
    3,249
    I've wondered the same thing every time I swim by one of those underwater spot lights they put in the walls of a pool.
    We had a lively discussion about this same topic - toasters in the bathtub and that sort of thing - here not long ago. There really wasn't a definitive answer except to avoid being the experimenter.
  4. morrobay
    Nov 7, 2013
    11
    Thanks, is it possible to quantify a safe distance away from the current path
    between pool lamp and drain ?
    And is there a 3-D description of the shape of current path ?
  5. #12
    Nov 30, 2010
    16,705
    7,358
    Only if you can quantify the conductivity of the water, the conductivity of the person, the conductivity of each ground, the shape of the person, the shape of the pool, the movements of the person, etc. Now you want it in 3D? Are you going to get in the water and test the results, or maybe ask your mother-in-law to test it?
    This is getting too spooky to continue. I refuse to further describe a way to risk your life.
  6. morrobay
    Nov 7, 2013
    11
  7. PackratKing
    Jul 13, 2008
    850
    216
    Wouldn't the chlorine content of the water have some bearing on its conductivity ? and if one checked the amp-draw on the light circuit, wouldn't it be abnormal if the water were charged to ground ?
    12 is right... This is one phenom. I am certainly not going to volunteer to quantify
  8. Dodgydave
    Jun 22, 2012
    5,166
    775
    Well i dont know what country your in , but the European standards are only 12Volt lights can be used in water,fed from a transformer with an RCD, so you wont get electrocuted.
  9. PackratKing
    Jul 13, 2008
    850
    216
    Yeah, that makes sense... one can get quite a lot of light out of 12v nowadays... and that would hardly be fatal even if it were leaking...
  10. wayneh
    Sep 9, 2010
    12,403
    3,249
    It's 120V AC here in the US, as far as I can tell. See here for example, or here.
  11. #12
    Nov 30, 2010
    16,705
    7,358
    The link in post #6 points to a Wiki about the electric field around a multi-kilovolt substation. It points out that you can get killed by walking on seemingly dry earth if you get too close. Getting in the water with a charged electrode and some fairly good grounds is thousands of times more dangerous. Wanting a 3D map of the kill zone kind of makes my head want to explode. Much like plugging LEDs into a wall outlet, if you have to ask how, you have no business messing with it.
    I asked the moderators to lock this thread. They have not, but the good sense of the local denizens seems to be working.
    ps, Chlorine content is one of the things that increase conductivity of the water.
    killivolt likes this.
  12. ian field
    Distinguished Member
    Oct 27, 2012
    4,459
    792
    Your next of kin could claim a significant wedge off the pool owner if they didn't have RCD breakers on the cables to any immersed light fittings.
  13. GopherT
    Nov 23, 2012
    6,330
    4,069
    My first thought was that this will never happen because any water against the bulb will simply short across the two leads to the filament and all surge will be within the same 1 cubic inch of volume in the lamp housing. I did not consider gross mistakes by an electrician - see Hilton Hotel (Houston 2013) story attached.
    http://www.khou.com/news/local/Family-files-lawsuit-in-hotel-pool-electrocution-death-226219641.html
  14. #12
    Nov 30, 2010
    16,705
    7,358
    Excellent source, Gopher. Morrobay can ask the Hilton Houston Westchase, Brown Electric, and/or the Martinez family to make a 3D map of the kill zone for him.
  15. wayneh
    Sep 9, 2010
    12,403
    3,249
    +1 Great link.
    It certainly answers the toaster-in-the-tub question to my satisfaction. You might survive but the odds are not with you.
  16. GopherT
    Nov 23, 2012
    6,330
    4,069
    After thinking about it more, it is very comparable to a magnetic field. Putting a piece of iron in a magnetic field will create a preferred route for the magnetic lines of flux and induce the lines to travel into (through) the iron.
    Likewise with a more conductive object (human) in a less conductive field (pool water). Even the chlorination (calcium hypochlorite), the ionic strength of the pool water is not nearly as high as the human (0.85% sodium chloride). It is likely the electricity could be felt more and more strongly as one moves closer and closer to the direct path of the current flow. More problematic if the current can flow through the heart or brain.
    killivolt and #12 like this.
  17. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    My pool lights are indeed 120VAC in sealed modules. The power runs through a rubber cord that exits the light fixture through a collet-type compression fitting and runs up a pipe to above water level and on to a J-box on the wall. Perfectly safe when in good condition.
    They are connected to a dedicated GFCI-protected circuit that has caused problems over the years due to leakage in the units as well as the 'waterproof' switches that control them. Each time, I dried them out, replaced seals etc. and upgraded the GFCI. So far so good.
    It sounds like the 'electrician' either bypassed the existing GFCI to fix tripping problems or missed/ignored the fact that it was missing. Either way, I can't imagine a case where any service to an underwater, line-operated light would not include a test of the GFCI.
  18. #12
    Nov 30, 2010
    16,705
    7,358
    This is why we don't tell noobies how to stick an LED in a wall socket.:D
    Griz and JohnInTX like this.
  19. KL7AJ
    Nov 4, 2008
    2,047
    295
    You are absolutely correct in this case! The old adage (hmmm...I guess all adages are old by definition), that electricity takes the path of least resistance is totally fallacious. It takes ALL possible paths!
    The math for volumetric conductance is extremely difficult, by the way, involving hyperbolic trigonometry in three dimensions. I've had to work out ground conductivity problems like this. Sure am glad there are simple nomographs for this. :)
    Eric
    Metalmann and #12 like this.
  20. #12
    Nov 30, 2010
    16,705
    7,358
    Arrrgh! Where were you when we needed you?:mad:
    Just kidding. If you did do a kill zone map the moderators would have smacked your knuckles with a ruler.:D
