Current output of LM2596
Discussion in 'General Electronics Chat' started by worldHello, Nov 8, 2014.
  1. worldHello
    Oct 15, 2014
    23
    So I want to produce 5 V and 2 V from 12 V. My plan is to use LM2596 buck converter.
    I want the output to be 2W-10W. However, it does not give me enough current.
    When it is 12V to 2V, the output current is about 5mA. What may the issue be?
    This is for a project. Hence, it is not for powering anything. The load is simply a resistor.
    Thank you!
  2. ErnieM
    Apr 24, 2011
    7,442
    1,628
    I suspect D17 is in backwards, but that is a complete guess.
    Got a schematic to post? Got picture of your build?
  3. ScottWang
    Aug 23, 2012
    4,933
    777
    Is this a home work or personal practice?
    Wrong diode, wrong conductor?
    Please show the bread board or pcb with parts, some photos.
  4. worldHello
    Oct 15, 2014
    23
    This is like a homework.
    I did not put anything around my buck converter. I simply feed 12 V in to the converter. There's nothing else
  5. b1u3sf4n09
    Member
    May 23, 2014
    115
    14
    http://www.ti.com/lit/ds/symlink/lm2596.pdf
    Attached is a link to the datasheet for LM2596. It shows a typical circuit layout for this converter on the first page. You will have to provide the external components that are shown for your switching converter to work. This is not like a linear regulator that simply dissipates unused power as heat.
