Current of a Power Antenna DC motor
Discussion in 'General Electronics Chat' started by Zdaddy, Feb 17, 2007.
  1. Zdaddy
    Feb 11, 2007
    5
    Hello.
    I'm building a robot and would like to drive it using 2 of these DC motors.
    It's the power antenna of a Volvo wagon.
    It works beautifully, and there is a big gear inside that spins at 38.5rpms at 9V. It has HUGE torque, you cant even stop it with your finger.
    Anyways, I measured the resistance of it and it came out to 1.68Ohms. What stumps me is while I had it running off the wall powersupply, it displayed that it was only drawing .3A. Whats going on? Shouldnt it draw 9V/1.68ohm = 5.36A???
    I need to know how much current it draws so I can start making a battery pack... Whats going on?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It might try to draw a few amps if stalled. When running, motors develop a "back emf" that limits their current draw. That's why stalled motors burn up.
  3. Zdaddy
    Feb 11, 2007
    5
    So when designing my battery pack...should I design it for 8A or less than 3A?
    Back EMF...hmm I remember I need to put a Zener Diode in there or something.
    Should I design my battery pack for 8A then?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You could just fuse the motors to prevent excess stall current (I have no idea of your application) or design in some active current limiting.
    The more current your batteries can supplu, the longer your robot can run.
  5. Zdaddy
    Feb 11, 2007
    5
    I'm building a robot that needs to find a line in a 4'x6' box. It is to start in any arbitrary corner. There are 3 notches in the line and each notch corresponds to a hole at some distance away from the line/notch. The bot is to shoot at that point, a pingpong ball into the hole. It must do all this in 2 mins or less.
    I'm sorry I'm a newb....what do you mean "fuse" the motor? Active current limiting...is that like an op-amp buffer circuit?
  6. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    fuse is a glass encased piece of wire that opens when the current gets too high. :)
  7. Zdaddy
    Feb 11, 2007
    5
    Oh that kind of fuse.
    Since I'm a newb I'm going to ask...dont fuses break?
    I think I'm going to scrap the idea of using the gears.
    there is way too much torque in them than what I need.
    I'll just fork out the $$ and buy the servo's my team mattes want.
