Dear all,
I have a mosfet h-bridge feeding the phase of an electric motor.
For measuring the current we were using so far a LEM LTSR 15-NP but now the ADC will be in the high power side and therefore the isolation given by this component is not an advantage anymore.
I am trying to get an accuracy of around 0.15 A for a ±15 A range. (0.5 % of full range)
Is this kind of device still a good option or a sense resistor could give better results? (or other way)
I think that probably a precision resistor (0.1% tolerance for example), plus the amplification and offset (to get a proportional shifted voltage between 0 and 5 V to be read by the ADC) could give better accuracy than the LTSR (0.7% accuracy plus 0.1% non-linearity), but probably the common mode voltage applied to the resistor could make a precise measurement difficult.
The switching frequency is 50 kHz, and the voltage supply for the bridge 170 V.
Thank you very much in advance for any advice!
Ricardo
Ricardo
