Current limiting Resistor
Discussion in 'General Electronics Chat' started by iONic, Feb 28, 2012.
  1. iONic
    Thread Starter AAC Fanatic!
    Nov 16, 2007
    1,422
    68
    I guess the question is not so much, do I need a current limiting resistor, as do I need a voltage dropping resistor.
    Pin 1 of this IC will sink 5mA when the charge voltage fall between .6V and .35V, at which point aprox. 5mA is sinked through D1(LED) and R1(Resistor).
    Not really sure what I need, an LED that lights up well enough at 5mA?
    Will an LED rated at 3V/20mA light up with a 400 ohm resistor in series and only 5mA passing through it?
    datasheets-LTC4054L-4.2
  2. #12
    Nov 30, 2010
    16,671
    7,314
    You missed a chart. Bottom left of page 4. The charge pin will dump over 20 ma to ground. Keep reading the specsheet.
  3. iONic
    Nov 16, 2007
    1,422
    68
    Oops! So Pin 1 is a Charge Indicator and not a Charge Complete indicator.
    Actually, both. When LED is lit, the battery is charging, When the Battery is charged, the
    LED should not be lit with only 5mA. Thus a 400 - 500 ohm resistor ought to work fine...
