current limiting resistor for optocoupler (4N35)
Discussion in 'The Projects Forum' started by onlyvinod56, Apr 21, 2009.
  1. onlyvinod56
    Thread Starter Active Member
    Oct 14, 2008
    362
    hello,
    I need to use 4N35 optocoupler in my task.
    I confirmed with the emitter side part.
    My Vcc is 12V on both sides of the opto coupler.
    Emitter side calculation:
    From datasheet, Vf = 1.18V If = 10mA
    So, R = (12 - 1.18) / 10m = 1.082K
    what values i have to consider for the transistor side calculation?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Optocouplers are not power devices. I usually arrange for more current through the emitter (more like 20 - 30 ma), and use a large resistor on the detector so the signal swings from 0 to Vcc. Something on the order of 47 - 68K in the collector should give a nice transition.
  3. onlyvinod56
    Oct 14, 2008
    362
    How can i use the datasheet to find this resistir (47k - 68K)?
    thanku
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That's just experience. I probably stuck one in a breadboard and swapped resistors around until I liked the result.
