Current limiting resistor for motor circuit.
Discussion in 'General Electronics Chat' started by ctrmint, Dec 29, 2012.
Thread Status:
Not open for further replies.
  1. ctrmint
    Dec 29, 2012
    I'm attempting to put a circuit together to drive a motor from a 12v supply but limit the current to approx 2A with a resistor. However I'm not sure of the resistance of the motor and thus unsure which resistor to use.
    I'm thinking a 6 ohm 50W resistor would be about right.
    Any ideas.
    Sorry I don't have much info on the motor as its a sealed automotive part.
    Thanks for the help
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    An elecric motor that runs at 2A probably needs 20A to start and when it is stalled.
    If you limit its current then it is useless.
    If you need to limit the current (and limit the torque) then use a smaller motor or reduce the supply voltage.
  3. ctrmint
    Dec 29, 2012
    i'm told the motor runs at 2A peak, its actually the drive on a specialist hydraulic pump and I very much doubt its pulling 20A.
    It used to control clutch packs in a differential rather than propel.
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    If the peak current of the motor is 2A then it runs at maybe 200mA.
    Or maybe it is only used for a moment when it is at its peak current?
    Why do you want to limit its current? An electric motor uses only as much current that it needs.
  5. ctrmint
    Dec 29, 2012
    i was trying to prevent it from pulling too much current and damaging it, as sort of safety measure.
    The component is approx 2k GBP, not the sort of thing to break.
  6. gerty
    Aug 30, 2007
    1,154
    304
    What's wrong with using a fuse of the recommended value ?
  7. #12
    Nov 30, 2010
    16,703
    7,341
    I'm with gerty. You are describing exactly what fuses were designed to do.
  8. ctrmint
    Dec 29, 2012
    i see your point about the fuse approach it does make sense.
    But is there a way I can limit the current, i'm just wanting to be in full control of how it will run. Also not really keen on replacing fuses every 5 minutes if the current goes slightly over 2A.
  9. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    How fast the fuse blows is depended on the type of fuse:
    This is from the wiki page on fuses:
    http://en.wikipedia.org/wiki/Fuse_(electrical)
    Bertus
  10. Ron H
    Apr 14, 2005
    7,050
    657
    Here is a 2 Amp limiter that puts only 0.33Ω in series with the motor when the current is below 2 Amps.
    You can make the series resistance even lower if you replace the PNP with an op amp (not just any op amp, though).
    #12 likes this.
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    I don't think a motor should have its current limited. When it starts it uses a LOT of current for a moment. If you limit the current then the motor might just sit there without starting and continuously drawing the limited amount of current until it burns out.
    Maybe you should have a circuit that detects when the motor is stalled (drawing a very high current and getting extremely hot) then the circuit disconnects the power.
  12. Ron H
    Apr 14, 2005
    7,050
    657
    I feel the same way. I just think the OP might have to see it to believe it.
  13. Audioguru
    Dec 20, 2007
    9,411
    896
    Which smokes the most, the current limiter or the motor?
    Both smoke the same amount?
    My electric RC model airplanes have a circuit that disconnects the motor when it gets stalled. One airplane's brushless motor makes music when it is turned on and it SHRIEKS and disconnects when it is stalled.
  14. Ron H
    Apr 14, 2005
    7,050
    657
    Yeah, you would need a BF heat sink for the MOSFET if the motor shorted out, or maybe even stalled.:eek:
  15. Jaguarjoe
    Apr 7, 2010
    770
    90
    Measure the resistance of the armature when the motor is stationary. This, along with I=E/R will be its peak current. I never had much luck fusing 12v DC motors, some fan motors start at 130+ amps and settle down at 10 or so. A circuit breaker is a better choice.
  16. RodneyB
    Apr 28, 2012
    651
    14
    The 0.33R resistor what is the wattage
  17. MrSoftware
    Oct 29, 2013
    545
    133
    The brushless motor is most likely a 3-phase AC motor. The controller feeds it high frequency power to make the "music". I believe the logic in the controller probably stops the output when the motor is stalled.
    For the other motors you might be referring to an auto-resetting fuse.
  18. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    Legacy thread, the OP has not been back since Dec 2012!:rolleyes:
    Max.
  19. be80be
    Jul 5, 2008
    432
    57
    He's been crying a long time he burnt up his motor waiting on it to start. Maybe.
Thread Status:
