Current limiting L298N
Discussion in 'General Electronics Chat' started by mbek, Nov 7, 2011.
  1. mbek
    Oct 30, 2011
    16
    Is it better to implement current limiting by using something like L6506 and thus modulating the INPUTs to L298 in some higher frequency PWM (found in application note), or connecting comparator to sensing resistor and using an AND gate to couple the comparator output together with my control logic's output pin which is supposed to enable/disable bridge on L298? I saw the second solution somewhere in the forums.
    I'm using half of each bridge to drive phases of brushless motors.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Why not just use the integrated L6506 solution? You'll reduce your parts count that way.
    I'm not too fond of the L298; it's really old technology. You'll dissipate a good bit of power just in the bridge itself; and you'll have to get rid of all that heat somehow.
    mbek likes this.
  3. mbek
    Oct 30, 2011
    16
    Well, power dissipation is really not that much of an issue because it will be implemented underwater with a metal housing used for cooling components :) But power consumption is an issue...
    And yes, I hate the L298 :( I'm using just half of each bridge (need it for brushless control), and it really does heat up too much, therefore wasting precious Wh.
    Is there an out-of-the-box half-H-bridge IC capable of at least 2A, or should I just take a couple of MOSFETs and make half bridges myself?
  4. jimkeith
    Oct 26, 2011
    539
    99
    mbek likes this.
  5. mbek
    Oct 30, 2011
    16
    Thanks, thanks to your link I managed to find _exactly_ what I was looking for - http://www.st.com/internet/analog/product/63243.jsp and http://www.st.com/internet/analog/product/63244.jsp
