hp172
Thanks for the schematic. So the circuit would need to operate for both foward and reverse of the motor, i.e. for opening and closing it. From what what I can see the schematic is for one dierection only and would seem tricky to get it to rotate the motor in both directions. I cant see any way at the moment of adapting the schematic to make the circuit operate for both directions.
What Mr Software said in his post about the auto-windows in a car is exactly what I am looking to acieve except with a butterfly valve instead.
The window in my car uses what is basically an auto-resetting circuit breaker, I forget the real name for it. Under normal operating current load the device is fine. When the motor stalls and the current goes very high, the breaker trips turning off the circuit and unlatching the relay. After cooling for a few seconds the breaker automatically resets. Are you looking for basically the same thing for your valve?
