Current Limiting Circuit
Discussion in 'General Electronics Chat' started by priya onkar, Aug 12, 2014.
  1. priya onkar
    Aug 11, 2014
    I designed Step up boost converter using 555 pwm ic for variable DC voltage, output voltage varies from 0-300 Volt.I have to design constant current limiting circuit at the output of boost converter which limits the current to 1 micro ampere.The purpose of this current limiting circuit is if short happens at load side then boost converter will not send current greater than 1 micro ampere.Please help me on current limiting part.
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    Put a large value resistor in series?
  3. ErnieM
    Apr 24, 2011
    7,435
    1,625
    No options are possible without a schematic.
