I have a regulated 500 VDC power supply (actually shows 545 V on voltmeter) that we wish to use to test a DC-to-AC inverter (designed for feeding dc from solar panels into the power grid). We need a minimum of 150 mA to get the inverter to activate. Without a current limiter, our power supply just pushes as much current as it can until the 1.5A fuse (on the ac side) blows. I would like to add an external circuit to limit the current to 200 mA. Most of what I have found searching around is for much lower voltage supplies. Could anyone point me to resource or suggest a circuit?
