Current Indicator
Discussion in 'The Projects Forum' started by Rohit Agarwal, Oct 4, 2014.
  1. Rohit Agarwal
    Oct 4, 2014
    Hi all :) I want to make a circuit that can give any kind of signal or indication when current through a wire increases above a particular value... any ideas??
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Read this data sheet for the ZXCT1009. There are a family of similar chips at Diodes Inc...
    What is the voltage/current of the circuit being monitored?
    What kind of output do you want?
  3. #12
    Nov 30, 2010
    16,671
    7,318
  4. Rohit Agarwal
    Oct 4, 2014
    Thanks for replying, I am working around 230 V (RMS) and 25 amperes.
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    Then forget the IC I linked to. You will need a current transformer, a burden resistor, a precision rectifier, and finally some filtering, for a home made solution. The alternative is to buy a calibrated AC Amps to DC transducer
  6. wmodavis
    Oct 23, 2010
    737
    150
    Use a fuse at the appropriate current. Also use an indicating fuse holder that lights up when the fuse is blown.
    Wa La...
    "when current through a wire increases above a particular value" the fuse will blow.
    When the fuse blows the fuse holder indicator will light and " give any kind of signal or indication"
    Elegant and simple based on your needs.
  7. inwo
    Nov 7, 2013
    2,435
    315
    These work well.
