Current in wire to set magnetic flux
Discussion in 'Homework Help' started by smarch, Jul 4, 2010.
  1. smarch
    Thread Starter Active Member
    Mar 14, 2009
    52
    A solenoid with a circular cross-section has a length of 10 cm, a radius of 3
    cm and is wound with 2,000 turns per metre of wire. How much current must
    flow in the wire to set up a magnetic flux density of 1 T at the centre of the
    solenoid, assuming that the inside of the solenoid is filled with air?
    I know I use the formulas H= nI/2 [cosθ_1- cosθ_2 ] and B = μ0μrH.
    But where do I get θ from?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Presumably at the geometric centre θ_1=θ_2=arctan(3/5)
  3. JimmyB
    Member
    Jun 1, 2010
    38
    Hi
    I tried it like this
    L=0.1m CSA=0.0028m2 N=200
    Found S 1st S= L = 0.1 =28420525 A/Wb
    .....................μ A (4∏x10-7)(0.0028)
    Wb=BA = 1x0.0028 = 0.0028Wb
    m.m.f = Wb x S = 0.0028 x 28420525 = 79577 A/t
    therefore I = F = 79577 = 397A
    ...................N 200
    or
    H = B = 1 =795774.7 A/m
    ......U 4pi x 10-7
    F = HL = 795774.7 x 0.1 = 79577 A/t
    I = F = 79577 = 397 A
    .....N 200
    I think this is correct, but I would imagine a 2.5mm2 wire with nearly 400A flowing being quite hot!!!!!!
    you might want to check the answer with someone...
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    I believe the formula for B along the coil axis would be of the form
    B=\frac{\mu_o NI}{2L}\[cos(\theta_1)-cos(\theta_2)\]
    Where L is the coil length and the angles are those subtended from the coil axis by a line extended from the point of interest to either extremity of the coil end edges
    Contrary to my earlier post I would have
    θ1=Pi-atan(3/5) and θ2=atan(3/5)
    I get an answer of 46.4A to achieve the required flux density of 1T.
