The 3-phase inverter is an electronic circuit that drives the BLDC motor by commutating the DC supply voltage to the three phases of the BLDC motor. The three-phase inverter has six power switches, two on each phase leg which are connected to the DC voltage source. Figure 3‑7 shows a three-phase full-bridge inverter. By activating a positive and a negative switch in two phase legs, the current flows through the transistor which conducts positive, pass through two phases of the BLDC motor and returns through the negative transistor.
My question is regarding the back current produced by the back EMF (Electromotive force). How is the current affected by the back EMF when the switches are not activated in a phase of the motor?
For example when S1 and S2 switches are activated, the current cross from S1 to phase-A of the motor through phase-C and by an S2 switch. What does it happen then with the current produced by the back EMF of the phase-B (eb)?
Many thanks in advance
