Current for 220v hp water pump
Discussion in 'General Electronics Chat' started by Juvi22, May 8, 2015.
  1. Juvi22
    May 8, 2015
    Good day everyone could I get some info Need to get a step up transformer from 220v to 110v for an half hp 220v pump wat would be the current
  2. Dodgydave
    Jun 22, 2012
    5,159
    772
    0.5hp is 373W, so @ 220V thats 1.7amps secondary side, primary side will be at least double that approx 3.5amps.
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    The problem with specifying a transformer for that pump is that the locked-rotor = instantaneous start current inrush is about 10X the running current, so the transformer must be able to supply ~30A for a couple of cycles of the AC waveform.
  4. Juvi22
    May 8, 2015
    Thanks a lot
  5. pafitis
    May 8, 2015
    16
    So one 1/2 hp at 22o volts its equal to 373W
    Now use the formula Watts divided by Volts, hence 373W/22oV makes as 1.69Ampere
  6. Juvi22
    May 8, 2015
    Appreciate the answers they were very helpful
  7. Reloadron
    Jan 15, 2015
    1,055
    275
    1 HP = 746 Watts that is a given. So logically 0.5 HP should be 1/2 of 746 Watts or 373 Watts. Now if someone could show me a motor with those numbers on the name plate that would be really cool. Never thought I would see a perfect motor in my lifetime. Most 1/2 HP motors I have seen draw considerably more, to deliver 0.5 HP many draw in excess of 0.5 KW.
    Ron
  8. JWHassler
    Member
    Sep 25, 2013
    204
    34
    Step up from 22V to 110V?
    Also, are you sure that the motor cannot be re-connected for 110V operation? Lots of single-phase motors can be.
