Current flow
Discussion in 'Homework Help' started by cole7894, Feb 16, 2012.
  1. cole7894
    Feb 16, 2012
    In a normal three wire single phase house service what is the path of current flow through out the full 360 degree sine wave?
    1) If polarity changes with the collapsing and expanding sine wave.
    2) Current opposes the force that creates it.
    3) Unbalanced current returns on the nuetral.
  2. Kermit2
    Feb 5, 2010
    3,841
    961
    Oh, good question.
    What did you get for the answers?
    We can see if we got the same one. ;)
  3. stirling
    Member
    Mar 11, 2010
    52
    you might want to point out to teacher (who presumably set the question) that current doesn't flow anywhere, anytime - never did - never will.
  4. justtrying
    Mar 9, 2011
    329
    398
    current is flow of charge, however we always talk about direction of current flow, not charge flow :D
    Wendy likes this.
  5. MrChips
    Oct 2, 2009
    12,623
    3,451
    I have no idea what you are trying to say.
  6. jegues
    Sep 13, 2010
    735
    43
    Care to elaborate?
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    The purists want to alert us to a great error in our thinking .....
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    Gentlemen, this is off topic.
    To the OP (original poster), the way homework works is you show us your work. We will not mock you if you got it wrong, but the idea it to teach, not to do your homework for you. If you did get something wrong then someone will point out the mistake and why it is so.
    Think about how AC works, it constantly changes polarity. This means, for AC, the current flow goes back and forth.
    There are many reciprocating ways of doing work, such as a old steam engine of yore, or the pistons of a car. Even though the average is zero, the movement back and forth can carry a lot of energy.
  9. cole7894
    Feb 16, 2012
    No unfortunatly it was a question sparked by the teacher when talking about phasing transformers and their polarity.But the teacher did not have the answer nor has anyone else who I have talked to so far.Looking at the circuit it would seem that either the Nuetral would carry source current summing with the polarity leg then returning to the source winding or the 120v loads between polarity and non polarity are in series.
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    Both Neutral and Hot are equivalent in terms of electricity, the same current flows through both.
    Neutral is connected to Ground at the power pole, so it is considered a "safe" wire, but this is not a good assumption for safety.
    The hot wire will show all the voltage on it, because it is referenced to both Neutral and Ground.
    Ground carries no current, and is there for safety reasons. A GFI (ground fault interrupter) works by sensing current through the ground wire. If there is current it is assumed there is a short in the system and the GFI turns off the outlet.
