Current Flow
Discussion in 'Homework Help' started by evowerke.com, Mar 21, 2007.
  1. evowerke.com
    Mar 21, 2007
    a) What is the current through the R1 resistor?
    b) If R2 has been changed to 10Kohms, Calculate the current I1 now.
    c) If I1 = 1 microamps is required when R2 is 10kohms, determine the value of R1
    i need some refreshing on my circuits and can anyone help me with my hw
    for the first question (a) would the following work? :
    I1 = V/R1
    10v/1kohm = 10mA
    for question (b) would the following work? :
    I1 = V/ R2+R1
    btw
    thank you very much :D
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Leave R1 out of circuit. Look at the potential between the points it connects to and think about what happens when R1 goes back in circuit. Make the change for R2 and look at what has happened to the potential between those points again.
  3. Distort10n
    Dec 25, 2006
    429
    Balanced Bridge. Nuff' said.
  4. Great_khaled
    Mar 26, 2007
    yes beenthere your answer like mine
