current flow help
Discussion in 'Homework Help' started by SWIT, Jul 16, 2006.
  1. SWIT
    Jul 16, 2006
    i need to know wat the current flow is if an inductor of 500mH is connected in parallel with a 1k resistor across a 110v, 60Hz source whats the current flow
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Solve for the impedance of the inductor, and treat it as a resistor in parallel with the fixed resistor. The values will be RMS volts and amps.
  3. SWIT
    Jul 16, 2006
    do u have a formula that could help me out cause i dont seem to get it i have a shity teacher thanx
  4. SWIT
    Jul 16, 2006
    thats the thing i dont know how to solve for impedence ive been trying to look for the formula and cant find it my teacher is whorthless
  5. JoeJester
    Apr 26, 2005
    3,402
    1,221
  6. SWIT
    Jul 16, 2006
    thats not helping cause u have to have current for that formula and thats what im trying to find out
  7. JoeJester
    Apr 26, 2005
    3,402
    1,221
  8. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    This is certainly the most straight forward method of answering this question. From one of the above links from JoeJester, the inductive reactance XL is given by:
    XL = 2*pi*f*L
    All of this information is given in you original question.
    Knowing this and applying simple circuit analysis will yield the answer.
    If you post up your attempts it will be easier to point you in the right direction.
    Dave
