Hi everyone
I need a current detector recommendation? I am NOT looking to measure magnitude just simple on/off output which is triggered by pre-set level.
I am measuring AC amps on an 110v device so the sensor should be a split-core to facilitate installation. The appliance is NOT a high-load motor and that is the problem - most industrial sensors such as Veris require minimum load to trigger the output, a load which my appliance can not attain.
I can't tell you what amps I expect since I can't monkey with the unit in order to connect my meter and I dont have one of those split core meters, mine is typical old multi meter which requires a total circuit interface for current measurement.
All I know is that the load is LESS than 1.5A since it can not trigger a Hawkeye Veris sensor which I have and that one requires min of 1.5A to trigger
The cable is pretty thick so I can't do the usual fix with multiple windings around the core of the sensor.
~B
~B
