Current density
Discussion in 'Homework Help' started by thexy, Jan 18, 2016.
  1. thexy
    Dec 13, 2015
    126
    Plot the surface current density in the shell as a function of the measured from the apex of axial coordinate z.
    So here is photo and result. I don't understand why are they using perimeter? Why is there tan?
    Can someone explain me on easy way because I don't understand anything. zadd.JPG
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    This is a shell, right (something like a very thin funnel)? So, at any given height, all of the current is passing through a ring. How long is that ring?
  3. thexy
    Dec 13, 2015
    126
    This is not easy explanation. I don't how much is long. I would say it's long like the time that currents flows through it.
  4. WBahn
    Mar 31, 2012
    18,085
    4,917
    This makes no sense whatsoever.
    What is the surface current density (which would be expressed in amperes per inch) if the current is flowing lengthwise through a cylinder that has a diameter of two inches?
  5. thexy
    Dec 13, 2015
    126
    It will be I/Area
  6. WBahn
    Mar 31, 2012
    18,085
    4,917
    No, because it is not asking for current density, it is asking for surface current density. So it is I/Length.
  7. thexy
    Dec 13, 2015
    126
    But I don't understand why is there tan?
  8. WBahn
    Mar 31, 2012
    18,085
    4,917
    What is the circumference of the shell a distance z above the apex? Isn't that a function of the angle of the cone?
