Current Control lm3600
Discussion in 'The Projects Forum' started by veerakumars, Apr 16, 2010.
  1. veerakumars
    Sep 18, 2008
    6
    Hai All
    I was doing research in SELECTIVE HARMONIC Elimination I want to control my rectifier current for that I am going for PFC. I attached the circuit I want to know roll of LM3600. I got these circuit from net I tried but with out knowing the application of LM3600 I cant proceed further help me.:(
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Can you make the picture larger?
    You can hadly read it now.
    Also cut away the large empty area.
    Bertus
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What you do is to use the "lm13600" as the search term in Google to find a data sheet.
    You may also find a superior device - http://www.national.com/mpf/LM/LM13700.html#Overview
    The design you came across is very old, using LM741 op amps. You could use more modern ones and perhaps get superior performance.
  4. Bychon
    Member
    Mar 12, 2010
    469
    41
    I already posted the data sheet on Electro Tech
