I am needing to build a circuit to perform a test on a part. It is from an automobile. The power source will come from right off the battery in the car. It will be a comparator circuit where a green LED will light if the current on this part is between 6 to 60 amps. If the current is below or above this value, a red LED will light. Does anyone have a circuit that will work for this test? I did electronics years ago and I am very rusty on my electronics now and I don't have time to go back and pull the books back out.
Thanks You!
Thanks You!
