Current Booster/Driver
Discussion in 'The Projects Forum' started by Cristopher Tingcang, Feb 15, 2012.
  1. Cristopher Tingcang
    Jul 31, 2011
    18
    Hi!
    I am working on my project nowadays. The output current of the power supply that I am using is around 500mA. As I used this supply to other modules in my projects, the current is getting smaller because the modules are in parallel. Can you suggest any device/electronic component that will retain the voltage of the supply but will amplify the current to supply all the modules that I have.
    Note:
    I have 5 modules that requires 12V supply with a minimum of 350mA current requirements.
    Any help about this matter is deeply appreciated. Thank you!!!
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    You can not amplify the current of a powersupply.
    You will have to use a larger powersupply capable of 2 Amp, to have a bit of headroom.
    Bertus
  3. Bernard
    Aug 7, 2008
    4,232
    414
    Is that 350 mA each module, or the total for all modules. When picking a supply, be sure it is regulated, or supply your own regulators.
