bountyhunter
- Joined Sep 7, 2009
- 2,512
The attached schematic illustrates the principle: use a 555 running at fixed frequency with variable duty cycle to drive a N-FET tied to ground. Connect the FET to the LED using a series resistor. As you vary the PW, the LED brightness varies. FET stays cool because it never operates in linear region (power resistor burns the heat)
The circuit shown could be simplified since you don't need to vary the frequency, just the PW. Connect the neg LED pin to the + output shown in the schem,
You would NOT need a current source at the top of the LED, just tie it to V+. The varying PW varies the average current through the LED which sets the brightness.
